RE: I need help removing a prop nut
Nate:
There is a tool that screws in place of the glow plug, with an extension that blocks the piston. It's commonly used by the car guys when tightening their flywheels on the crank. Using that will let you get the prop nut off easily.
But heating the nut with a torch should work too, just don't heat the crank end.
Bill.
