RE: I need help removing a prop nut
Remove the glow plug, and fill the cylinder with some string. I will work like a piston stop and keep the crank from turning, without damaging the piston or cylinder. Just make sure you leave the end hanging out of the glow plug hole, so you can remove it. Cord about the size of string trimmer starting rope works best, but anything close will do.
