RCU Forums - View Single Post - Setup with DA50
Old 12-21-2003 | 10:59 PM
rctom's Avatar
rctom
Default RE: Setup with DA50
ORIGINAL: rodg2039
RCTom,
How is the vertical? Can you aim straight up, stop and punch it and have the plane climb out? If it does how would you explain the climb out? What type of batterys are you using? Do you have anymore pics of the setup? I got a CF landing gear that I had purchased for my cap that I plan on using, getting a CF tail wheel from graphtech, and might get the CF tube from Troy built. Then just trying to decide if I should use my NiMH or go with duralites or powerflights. Just want a nice light setup.
Brian
Vertical is great, yes it will pull out vertically from a hover. I use 6 volt NiMH packs 1650 MAH. When you buy all that CF stuff you will have removed more weight from your pocket than you will from the plane. The upgraded stuff is very light, save your money.
You guys that stress over every gram should fly the plane first before you invest in a bunch of lightweight components. I find that I like it better with the G62 than with the DA-50 because it's more solid feeling.
TF
