RE: BME 50 Help!
I have that combo exactly. The servo hook-up is easy. If you have a dremel tool with the composite cutoff wheel, use it as a grinder and remove that small brass lip from that arm. Once you have ground it down level, the arm will pop off. Buy a $2.00 dubro steering arm, some nyrod, a servo, set it at the angle you want, and you are good to go.
