RCU Forums - View Single Post - Will crack in engine mount cause problem??
Old 12-23-2003 | 10:08 AM
CafeenMan
Default RE: Will crack in engine mount cause problem??
If the crack is behind any engine bolt then replace it. It's dangerous and not worth the risk. If the crack is at least 1/8" in front of the forward bolt then it should be ok.
