RCU Forums - View Single Post - Will crack in engine mount cause problem??
Old 12-23-2003 | 10:19 AM
Montague
Default RE: Will crack in engine mount cause problem??
Just remember, the vibration levels from a running engine can do far more damage than you can "feel" with your hand. I don't know about you, but I can't back out screws with my fingers, but my engine sure is good at it if I don't use locktite
Great advice from CafeenMan.
(oh, disclaimer time, I have acutally flown with cracked mounts, but as CafeenMan indicated, the crack was small, and in a location such that even if it failed, I'd lot have the engine come off. And it was on a plane that gets a lot of pre-flight attention and maintenance anyway).
