RCU Forums - View Single Post - Sky Master F-18 First flight
Old 12-24-2003 | 04:51 AM
  #33
Ali's Avatar
Ali
Default RE: Sky Master F-18 First flight
Tam. Of course you can use any of my photos. If you need any more please let me know and I will take some for you. I can also email them to you direct if you want
SJ. For skymaster from the Uk try www.alshobbies.com
Rider 60. I have a Skymaster F-15 that I flew for 20 flights with no balance on the stabs. I thought I would try to balance them to see the difference. The only difference i found was the model was a lot more tail heavy. This was because for some reason I forgot to add nose weight to counterbalance the lead in the stabs. When I do another one I will not bother balancing the stabs. As Tam said all the flying stab models I have are equipped with high torque servos and I never have any problems
