RE: Aerotech
I have an Aerotech Sea Fury. I'm lucky in that all of the parts are present though the middle section of the instructions are missing. No biggy though as it's a very simple build. I'm not even going to try to get the rest of the manual. The control surfaces had me scratching my head for a while. They are WAY too thick. The obechi is too thin to allow for any sanding to get the fit and I don't really feel like carving or building up new surfaces. What I ended up doing was cutting the surfaces in half, lengthwise and sanding down the foam then glueing the top and bottom halves back together with ProBond. It was a small amount of work compared to building new surfaces and worked quite well. It's too bad they couldn't have been correct out of the box.
John
