RE: I need help removing a prop nut
I would have thought locking the piston in some way and trying to undo the prop nut is about the best way to bend the con rod.
I bet the nut will come off if you heat it, place it sideways so one flat is on a very heavy piece of metal and tapping it on the opposite flat.
-David C.
