RCU Forums - View Single Post - DO-IT-YOURSELF VACUUM BAGGING??
Old 12-25-2003 | 06:17 PM
rraimonfl's Avatar
rraimonfl
Default RE: DO-IT-YOURSELF VACUUM BAGGING??
David, I think you may have the answer to my problems. Actually as you suggested to Tom, I have a male mold to which I will lay the glass over. I was also looking for bagging, but I guessed just what you also suggested, that it will not be easy to obtain good results when having compound shapes, as I have. Now, here is my nightmare: How can I make the fiberglass to "stick" to the compound shapes? FYI, I am working in an XF35, and I have split the fuse in upper and under sides. Although the F-glass cloth can stretch to the shapes, it tends to "short cut" to a more straight shape (cross section view).
Richard
