RCU Forums - View Single Post - fiberglassing
Old 12-25-2003 | 09:40 PM
combatpigg's Avatar
combatpigg
Default RE: fiberglassing
HI HARLEY! I can tell you about a quick and easy way to do small jobb glass work. You will need MEDIUM CA GLUE< 3M77 SPRAY ADHESIVE, LATEX GLOVES, and 2 OZ CLOTH for most applications. Cut the cloth out to what ever pattern is needed. Grocerie bag paper is good for developing a pattern. Spray a light coat of 3M77 on the cloth. Apply the cloth to your model, the adhesive will keep it in place. Cut a finger off a latex glove and slip it on your favorite finger. Spread some medium CA glue out on the cloth and work it in with your finger. Hit it with a quick shot of ZIP KICKER and you will be ready for final sanding before you can find your sandpaper. 2 layers of cloth can be laid before gluing if you need tons of strength.
