RCU Forums - View Single Post - OK, So I screwed up!
Old 12-25-2003 | 11:02 PM
JimRoss
Default RE: OK, So I screwed up!
Well, the backplate fit perfectly. I did have to take off the old gasket and use the one that you sent with the backplate. For some reason it wouldn't go in the hole on the old gasket, so I jsut replaced it. Perfect match, carb hooked up, screws all tight, ready to do some sawing on the excess metal and flywheel.
Thanks again,
