RE: Landing problems
I would suggest carrying throttle to touch down. If your idle is low, and with the Saito's you can get real low, then in your first example, with the 14X4 you might as well envision a 14 inch pie pan on the front------------that's a lot of drag.
By carrying enough power to create some thrust you wont find youself settling short.
