RE: Which R/C Flight Simulator do you have?
All Thumbs,
I've been thinking about buying AFP. Do you have the version with the controller, or just the interface version? If you have the version with the controller, can you use your own transmitter? I have a JR 8103. Also, isn't there a security device that plugs into a serial port? Is it 9 pin or 25 pin. Is it a pass-thru device allowing a serial device to be plugged into it?
Hope you or someone else can help answer my questions.
Bobby
