RCU Forums - View Single Post - G2 Interface problems
Old 12-26-2003 | 06:04 PM
pt19 flyer's Avatar
pt19 flyer
Default RE: G2 Interface problems
hi andrew
I have G2 and running XP and have the eclipse 7. I tried the tx with the interface and it worked fine...the TX does have to be turned on however. you could have a bad interface...unplug the cables and reconnect.. I have on board sound but am going to add blaster sound card, everyone claims this is a big improvement.
make sure your game port is active. do you have onboard sound or plug in card. you might restall drivers for sound card. if you have onboard modem and sound could be an interrupt problem. are you using the com port or game port. this would be the problem.
good luck
joe
