RCU Forums - View Single Post - NEED AERONAUTICAL ENGINEER FOR PATENT/PLANE/ENGINE DEVELOPMENT
Old 12-26-2003 | 08:40 PM
NathanAustralia
Default RE: NEED AERONAUTICAL ENGINEER FOR PATENT/PLANE/ENGINE DEVELOPMENT
Hello all,
Thanks for the real replies!!!!
I am sorry if you have your own personal thoughts on what I wrote, you really need to have a look at the real information in the post.
I would like to clarify something. There are two designs here. One for an engine and one for a VTOL/UAV aircraft. They are NOT related.
I believe that I have designed an engine that is revolutionary. It uses current technology in a different configuration with a slight twist. This is why I know that it will get to the speed I am talking about. I know that I can get the engine from 0-10000km/h with current scramjet development there should be no problem getting it to earth escape velocity.
If you think I am being optimistic, I am. I am because have you ever heard of a jet engine that can go from 0-earth escape velocity with one moving part? Or a scramjet engine that starts from 0 km/h without some other outside propulsion system. Dont you think that would revolutionise space/defence and civil aeronautics?
All I am looking for is someone to help me get both designs fine tuned. I am in no way ready to build the engine, but the Aeroplane, I could if I wanted to at this point. Either that or just go to some defence contractor.
The reason I asked for a genius was because I want someone who has knowledge in all areas possible, oh and I am classified as genius. I have a guidance system and I am doing a degree in software engineering so that I can fine tune the one I have already.
And to the guy who said the patent is the solution then you are obviously not thinking. Its not the solution its just another problem once its done.
THANKYOU AGAIN TO ALL THE REAL POSTS.
nathan
