RE: Deseil Vs. Glow
50% power increase depends how you look at it that is not across the board per se
on diesel they will turn increased diameter and pitch which is more thrust and your
fuel economy will be much better up to twice the time on same size tank, 11x7 and
12x6 are what I run which are wood zingers with a fairly wide blade the apc comp
props will run at least 500rpm faster
