RCU Forums - View Single Post - Question for you laser cut kit builders
Old 12-27-2003 | 12:36 AM
scott7x71's Avatar
scott7x71
Default RE: Question for you laser cut kit builders
The only time I've sanded any laser-cut parts (other than the tabs) is when the plane is going to be covered with clear/opaque covering because the black lines show through. Otherwise it's not worth the work just to loose the great fit.
