RCU Forums - View Single Post - Nexstar Crash....
Old 12-27-2003 | 01:51 AM
ethrjock
Default RE: Nexstar Crash....
1. Did you like the plane enough to want to continue with it?
2. Do the fuse and wings kits give you a complete airframe, or can you unbolt the tail easily? Considereing the price, you'll want an as good as new airframe when you're done....
Thanks for the comments Tigger
1. Yes I do like the plane. It flew quite well. I was looking forward to taking off the "flaps" as they were lifting the plane too much during flights. It took almost all of my elevator trim at the radio to make it fly level.
2. The tail fin and elevator does unbolt and was not damaged in the crash so I will re-use it. The rubber motor mount did break and so did the front landing gear...so add another few bucks and I am up to $140.00
3. I meant the MKII.
4. Is the sig a semi airfoil?
I do wear glasses but I can clearly see the plane....i just misjudged the distance the plane was from me. BDTSR. Did you have to have special lenses cut for the distance problem? My current prescription just deals with my near sightedness...
