RE: Some Bad things about ARFS
Two main things you fix when you buy a new Arf. The first is the firewall. Always add some fiberglass cloth or milled fiberglass on the corners. its not a time consuming thing but gives it added strength. Same thing on the retract mounting blocks if you have them.
Arfs a great, they save quite a bit of building time but in some ways they are slapped together and need some work.
