RCU Forums - View Single Post - dizzy newbie
Thread: dizzy newbie
Old 12-28-2003 | 03:00 PM
rnlocnil
Default RE: dizzy newbie
I think this engine is probably between 10 and 20 years old. I guess I found it 6 or 8 years ago in the trash. When I practice spinning, I hold out my hand and watch that. I was thinking about Spiderwire or something as I bet it's almost as thin as the steel.
Something I've noticed is that the lead ins on CL models seem to be pretty far apart. I'd think that putting them closer together would cut drag quite a bit, out near the model. But I guess you'd have to have a real strange handle or else hold the handle horizontally to keep the wires even with each other. Not worth it for a Stunter, probably.
My model looks like it's going to weigh just under 5 oz. Way heavier than it could be.
ORIGINAL: gcb
rnlocnil,
Some more opinions:
The recent product engines Cox puts out seem to be pretty good little engines.
Although .008x 42' or so of braided SS lines are preferred, you may want to use about 35' of Dacron or Spiderwire while learning. I think the line that comes with the handle is still Dacron. Each time you step on them or tangle them, count that as an oops to handle them better. As mentioned previously, stainless lines are strong but fragile.
Try to fix your sight on the background and watch the plane fly by. Check out how dancers do it when they spin around. The dizziness will go away. It's just something your body is not used to.
Welcome to CL. Hope you enjoy it as much as RC and FF.
George
PS. BTW, check out the Brodak Flite Streak Jr. and Flite Streak Trainer for the OS .10. Just wire the throttle open and run it with a carb.
