RCU Forums - View Single Post - ignition problem on ryobi
Old 12-28-2003 | 07:58 PM
pa28140
Default ignition problem on ryobi
what i thought was the carb problem turned out to be an ignition problem, after tearing the carb apart and examing everything over several times I discovered that ignition only works at low rpm...is this an ignition coil(i thinks thats what its called) problem or the flywheel?
thanks
