RE: Sukoi 1/3 Scale????
I bet you wouldnt have had to add that much weight if you would have brought your rudder servos internal around the CG and used a Gang system. Plus a CF tailwheel would have cut out on a lot of that. If you can save 6oz. in the very back then you can cut out on the majority of the weight you had to add.
