RE: U Cant Do good Elevators? Try Spoilerons!
Does your pmix have a parameter is the setup to "link" on or off? If so and your second aileron/flap is on channel 6 you should be able to turn the link on and control both surfaces from from 1 mix. You may have to set the rates opposite,i.e. one -50% and one +50% but it should work that way if you have it??
