RE: Sig Li'l Rascal wing modification
Well guys after much experimentation and a few shaky flights I can say that it flies as good as it's going to get, the set up is with the Cirrus 4.4 servos, a JR 610 RX and a 3 cell 340 Kokam, One thing that I found out the hard way is that you have to put some locktite on the gearbox, It started making some really bad noises after maybe the 8th flight. Other than that It flies Ok and it looks so cool in the air with plenty of climg authority thanks to the 3rd cell, I did set up dual rates just in case and it worked out ok.
