RCU Forums - View Single Post - lateral balancing
Old 12-30-2003 | 02:28 AM
combatpigg's Avatar
combatpigg
Default RE: lateral balancing
HI SDC..AIM has given you a good way to go. If the wing tip permits it , I drill a pilot hole and counter sink it for a woodscrew. To fine tune, cut the screw, or go with a longer one, other wise you can drill 1/8" holes and use plumbers solder and CA glue
