RCU Forums - View Single Post - RX Ant. Length
Old 12-30-2003 | 06:33 PM
kenru
Default RE: RX Ant. Length
The formula is 2952/Freq (in MHz) = 1/4 wave antenna in inches. The wire size doesn't matter because there is immeasurable current flow in the wire. The antenna may be wound around a non-conductive form or left straight with the only change in characteristics being a slight reduction in range for the wound configuration.
