RE: first profile kit?????
I haven't built one yet, but the Burrito from PaulSwany looks like it will go together real easy. His FF Taco kit literally fell together, and the Burrito uses the same construction methods. The wing should be even easier because there is no taper.
For tools, most profiles require you to cut a lot of sticks at various angles. For this, a good razor saw and one of those miter sanders come real handy. Can't remember who makes them, but they're only about $15 or so and you can set the desired angle and san the ends of sticks for perfect joints. A good flat building board is a must, along with a bunch of pins for holding parts down. Other than that, you probably have everything else you need.
