RE: Lateral balancing techniques
Good post. I do it about the same way, and I keep a roll of solid core solder around for weights. I just lay a piece of it on the wing where I want to attach it, as far out as possible, and cut it off until the weight's right to balance the wing. Then I roll it up , usually into a flat coil, and CA it to the rib or wingtip, whatever's handier.
