RE: What Are Some of the Easiest Building Kits?
If he would consider a slightly smaller plane all the Herr Kits are impossible to build wrong unless you try. They fly great and use little fuel because the use small engines. The J3 is great to learn on as is the Starcruiser. Most are designed as 3 channel, as most primary trainers are, but can be built with full house controls easily. I've built many kits but these are by far the easiest and fastest. They are distributed thru SIG Mfg.
