RCU Forums - View Single Post - Adding right-thrust/down-thrust to model
Old 12-31-2003 | 03:39 AM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: Adding right-thrust/down-thrust to model
ORIGINAL: dwango
I just placed an order for a CG Super Chipmunk and various accessories. Among these accessories was a one-piece pre-tapped OS engine mount for my OS FS-91 Surpass II four stroke. I've read that the Chipmunk requires some right-thrust and possibly some down-thrust. Do I have to be able to drill custom off-center holes in the engine mount to add the right-thrust, or is it set by the angle of the firewall? I'm asking because I'd cancel the OS engine mount order if its not going to be able to give me the required right-thrust (since the mount holes are pre-drilled).
TIA.
Get Ernst thrust plates. They come in 1,2, and 3 degrees. Quantum and TH carries them
