125$ + has a wireless camera included as well....
This newly designed and released 3-CH R/C Airplane glider/plane kit has a extra large 42 inch (over 1 meter) wingspan and is RTF (ready to fly). It includes a motor, two micro servos with control rods pre-attached, and receiver pre-installed. The kit also includes a 3 Channel radio transmitter, a new powerful 8.4V 600 mAh NiMh (nickel metal hydrade) battery flight pack, and charger. Basically this kit has everything you need to fly the day you receive your package except for the 8 AA batteries that you supply for the radio transmitter.
This aircraft operates as both a motorized glider and a plane. The huge wingspan in combination with lightweight construction and the powerful 380 Mabuchi type motor provide terrific lift. Once airborne at high altitudes simply use the variable speed control on the transmitter to adjust throttle speed or simply turn it off completely glide and collapse the prop in flight for maximum airborne flight time!
Features:
Full 3 Channel capability with a variable speed throttle control
Digital proportional standardized radio control system.
Motor controller has a sensitive reaction, has a low voltage drop and strong anti-interference.
Interchangeable crystals are available on 3 separate frequencies making for trouble free competition or flights with pilots who have planes up concurrently.
Newer high performance turbo 380 motor that uses low electric current while maximizing power.
Easy for a beginner to operate because it is lightweight yet has a sturdy construction.
Reversible rudder and elevator controls.
Battery: New and improved Ni-Mh (8.4V) for longer lasting flight time.
Neck-strap holder pre-installed on all radio transmitters.
Tow holes included under nose.
Excellent high altitude slow gliding/soaring. Extraordinarily stable to use as a UAV (un-manned aerial vehicle). The plane can naturally take on the added weight of a micro-camera with just minor adjustments to it's center of gravity.
Excellent gliding function. By adjusting the speed of the motor to a lower level of throttle, the prop will collapse in flight to reduce resistance and maximize aero-dynamics.
http://store.yahoo.com/raidentech168/3rarecoaiwis.html
