RE: <span class=
Havent had a chance to fly it yet. Still working on an elevator problem. Using two servos and can't get them balanced as far as throw and speed. Getting two Hitec's one of which is reversed and hopefully that will cure the problem.
The hatch worked out fine. I cut out a piece from the bottom and glued small plywood tabs inside where I could put screws through the hatch to secure it. Made hatch from 1/8th lite plywood and covered it with black covering. Matches great.
