RE: Vectorflight extra 300, which size
Yup. My Goldberg 300 is closer to 12 pounds with the smoke system, gear replacement and repairs, and tail reinforcements for the three servos.
It flat out screams with a 1.08 and 16x6. I can't "fly" it at full throttle... generally run it a little above half throttle for straight and level flight.
If I were to do it again, I'd use the .91 (or a 1.20). At the time I built mine, the .91 and 1.08 were the same engine block, so the 1.08 was a touch lighter. Today, with the FX series, the .61 and .91 are the same block, so you're looking at a significant weight savings, and still more than enough power.
My buddy built a Goldberg Ultimate, but decided to cover in Solartex and then paint it. Three coats of primer and two coats of paint plus a clear and it ended up at 14 pounds. Flew like a brick with an old OS Max .80 (dual glow plugs!). He dumped that for a Magnum 1.08 (ABC, OS is ringed) and it now has unlimited vertical. The Magnum 1.08 swings a prop 1 inch smaller than the OS 1.08, so I'd guess that the FX .91 would be comparable in power to the Magnum 1.08
