RCU Forums - View Single Post - Feul tank set-up for a 2-stroke with pump
Old 12-31-2003 | 04:04 PM
TOYMAKER
Default RE: Feul tank set-up for a 2-stroke with pump
No need for a check valve. It will only create problems. You can run muffler pressure to the vent and this will help with the high end needle setting, but in most setups is not needed.
WG
