RE: difference between OS pre-surpass and..
Hello John, The valve is just one of many differance's that make the surpass models different. case designs that allow better cooling, some have larger bearings than there non-surpass counter parts. The Intake valve's larger, but so is the port, & the intake track (path the air-fuel take) has been improved for better low & high speed air flow. Larger carburater's, & pumps on some to allow more consistant fuel delivery from full to empty tank. Some improvments in the exhaust also allow better flow. The camshafts are different. Allowing a wider duration of total valve timing, a higher lift, & a longer full open duration (wider nose of the lobe). Some also have a different rocker arm ratio, allowing a slightly higher valve opening from any given cam lobe height. All that to say the surpass serie's were developed to improve on the 4-stk power output that some earlier engine's just didnt have. Not to say the old ones are no good, just not as powerful as the newer one's are. I have an old 120 with the separate valve covers. still runs good. My surpass's have a little more power, but the plane the old one's in is not a high speed type. The power is right for the plane it's in. Hope this help's & good luck with it. proped right, it will serve you just fine. ..............Mildbill
