G45 Muffler Stack
I am having a problem with the muffler stack cracking on my 45 engine. The plane has experienced some very minor crashes. I have balanced the prop and spinner. I am going to have someone check the crank to see if it is bent. Otherwise I am out of ideas. If it is the crank is it feasible to replace the crank and bearings. If so can you list a supplier for the parts.
Ray
