ORIGINAL: BigSTIK40flier
ok on balencing the magic in inches not metric what is the starting balence point and after the plane has been trimmed and ive gotten used to the controls where should it be, thanks
Factory spec starting point is 115mm = 4.52 inches. Mine flys like a calm sport plane on low rates with that setting. You could probably train with it. Depending on how and what you want to do later on I have seen 5 to 5 and one half inches as the common CG. Good luck and enjoy
I also fly a BigStik40 haha.
