RCU Forums - View Single Post - Which airfoil to use???
Thread
01-02-2004 | 02:15 PM
2
DICKEYBIRD
Apr 2002
2,749
Collierville, TN
RE: Which airfoil to use???
Kinda depends on what you want it to do, wing loading, etc. Here's one (S8036) I like, designed by the good Dr. Michael Selig, wind tunnel tested at low Reynolds numbers and is the root airfoil for the Top Flite P-47 kit that does very well. I've used it on several designs myself and on projects I've helped friends with. It s stable, clean and flies decent inverted. If you're doing a tapered wing, the companion S8037 for the tip with a couple degrees washout does really nice.
(Top one is S8036)
If you need a .dxf or .jpeg let me know the specs and I can send it to you.
Reply
Like
DICKEYBIRD
View Public Profile
Send a private message to DICKEYBIRD
Find More Posts by DICKEYBIRD
View iTrader Profile
