RE: YS 63 Problems
What you are thinking is "detonation" may be an engine that is bucking in the mid range because it's too rich. Go to the general instructions at ysperformance.com and go through the setup on this engine again.
Also, take a look at the valve clearance. It should be .003" on both valves with the engine cold. Do this before going through setup.
