RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 01-02-2004 | 10:42 PM
  #737
Grrrrrumpy
Default RE: U-Can-Do 3d 46?
Ok guys, I got a Rossi .45 which is suppose to have 2.1 hp. With a 12.25 X 3.75 prop, will this be enough to hover the UCD?
Here's the plan:
mount the engine right side up to prevent the fuel from siphoning out (a hole in the top of
the cowl won't be all that bad)
cut a hole to mount the right elevator servo higher so the control horn is down to eliminate using a servo reverser.
mount the 90 oz pull-pull rudder servo on the under side right behind the wing for the CG problem.
fiberglass the landing gear
install tall wires (lines)
use 4-40 rods
Any other suggestions?
