RE: Who can answer this ONE?
The plane is just nose heavy, that is why the up elevator to fly flat and level. Move the CG back 1/4" at a time and try until you need almost no elevator to stay inverted. That will put CG where you want to be. Watch out for overcontrol. As CG gets nearer where it should be, the plane will become much more responsive, and your elevator throws may be much too much.
Les
