If you add the E-Tech Lithium Batteris and the Orion Elite Motor, (for the Feda DragonFly), Do you have to adjust the gear ratio, change the controller board chips, or anything like that, or is it as simple as replacing the motor and popping on the new battery??
I've seen a few 7.4v LI-POLY batteries that are up to 8000 mAH (2, 3 and 4 cell configurations) - can you use these just as easily if the weight isn't too much? Since my Ni-MH battery is 8.4v, I wasn't sure what this would do to the controller board.
http://www.aeromicro.com/Catalog/bat...2_products.htm
Anyone know? Thanks in advance!
cornwell
