Glowfuel....
Quote: "Normal, level flight needs about 1/4", up trim, delection to keep
the model flying upright, straight and level."
Look at the horiz. stab. It is mounted incorrectly...being that it is glued
onto the top of the fuse, at the rear....with a wild up angle. [X(]
Normally it would be mounted at the same angle or incidence as the
wing....however, in this case....being a flat bottom trainer type plane,
the wing shoulg have about 2 degrees positive incidence at the front.
(about 3/16" will do)
That's why you have to give up-trim for level flight....and that trim is
making the inverted flight even worse.
Dave.
