ORIGINAL: raptorheli
i've had no luck with this mate, it is only a problem on laptops as far as i know. afp forum is useless. they want to know everything to make a diagnostic decision.(CLIP)
cheers
They can't perform brain surgery from afar without knowing the problem. Usually all they want is the data file from AFP and your hardware. Seems reasonable to me. BTW, I am running AFP with expansion pack 1 under XP Pro with no problems. Have you installed the latest (1684) patch? Be sure to install AFP, then the expansion pack and finally the patch.
Good luck & Happy New Year.
Gary
