T-MaxX not downshifting properly
Hello. My truck appears to have a transmission problem and I thought maybe some of you guys might know what's up. The truck is about a half a year old with just about 6 gallons through it. My problem is when I am just bashing around in my neighborhood, it'll shift up into 2nd fine, but then when I stop, many times it will remain in 2nd. So when I try to go again, it does a 2nd gear start and is slow. When it gets stuck in 2nd like this, I have to monkey around with the throttle and brake to get it to go back into 1st. It doesn't happen EVERY time, but more often than not, it does happen. Also, since gallon 5 or so, this problem has gotten worse. It's definatley not a shift-point adjustment problem, cause it upshifts when it should, and i've messed with the shift point screw before. I have not had the tranny open and apart yet. Reasons for the truck not downshifting that I suspect are: cold weather, worn/broken transmission part(s). Help would be greatly appreciated...thanks
