RCU Forums - View Single Post - Prop sizes..
Thread: Prop sizes..
Old 05-22-2002 | 12:28 PM
Fastsky's Avatar
Fastsky
Default landing speed
Sounds like you are just keeping the plane level until it lands. Try adding in some up elevator on the final approach. It will raise the nose and start to slow the plane down. An LT doesn't need much speed to keep flying and you can control how fast the plane flys forward by the amount of up elevator you put in. You will be amazed at how slow you can bring it in. Add the up elevator slowly and watch how the plane slows down. You will get to the point where the speed is comfortable and at that point just continue to hold the elevator stick at that position until its ready to flair. Then add in the rest of the elevator as the plane is touching down. This method also prevents bounce on landing.
I have a low wing that has to be landed this way or it use the entire runway to slow down after touchdown. Have fun, Fast!
