Prop sizes..
Quote "The idle is as low as it will go. when on the ground at idle it will barely move."
Just curious, what rpm is your idle. If you are on grass your plane should not move at all at idle. But if you fly off concrete, it'll almost take off at idle. Are you landing on grass or a hard runway?
