RCU Forums - View Single Post - Sig 1/6th J3 Cub
Old 01-05-2004 | 01:32 AM
tubig
Default Sig 1/6th J3 Cub
working on a 1/6th scale Sig Cub among other things. Sig calls this a "Craftsman kit" probably because it's about as close to scratchbuilding as you can get in kit form. very similar to the Marutaka kits in that you get a lot of sticks and sheets which you put together by trial and error fitting and shaping....which is fine with me. this kit takes a lot of time and patience and makes a good long winter build if you like that. to give you some idea how old this design is, the copyright date on the plans is 1975.
a pic of the fin and rudder. still needs shaping of leading and trailing edges and hinging.
