RE: *Who can answer this ONE?*
The tail feathers should be mounted more like this. If the plane is
balanced on the spar....and if the plane has positive incidence in the
wing.....which some flat bottom planes have....
....you will need "down trim" in the elevator, because flat bottom
winged planes climb like mad at speed....not "up" trim.
